Zero Trust building blocks - Leverage F5 NGINX Plus Single Sign-On (SSO) and F5 XC
As part of your organization journey to build a Zero Trust strategy with distributed Microservices, you would think of a light weight engine that allows to perform request authentication and authoriz...
Published Jul 06, 2023
Version 1.0momahdy
Employee
Principal Technical Marketing Engineer - Focus on BIG-IPNikoolayy1
MVP
Aug 30, 2023I think it is better to install the Nginx in the RE or CE vk8s as shown here https://community.f5.com/t5/technical-articles/enable-saml-service-provider-on-f5-distributed-cloud-application/ta-p/316166 .
Maybe in the cases where Nginx is a ingress controller in a Amazon EKS then it is not in the CE/RE and the CE can also be a pod in the Amazon EKS. That will be an interesting article making the two pods (Nginx and CE) to work together as one will be the Ingress.
