MSZ's avatar
MSZ
Sep 25, 2017
[WSS ] illegal URL
Hi I am getting the following msg (Blocked) in event logs [WSS] illegal URL ANy idea abou it. Using version 13.x
  • The transaction must be a false positive. Did you try to learn the suggestion? Go to, Security >> Application Security >> Traffic Learning, find the URL that is blocked and try to learn the suggestion
    • MSZ's avatar
      MSZ
      Please review the question again. This URL is working properly with HTTPS. I am getting blocked requests with WSS
  • ASA MSZ,
    It seems that your application use Websocket.
    • WS (for unencrypted text)*
    • WSS (for encrypted text)
    As for HTTP/ HTTPs URLs, you will need to specify within your ASM policy "Allowed Websocket URLs"
    You can define allowed URL either using "wildcard" from :
    Security  ››  Application Security : URLs : Wildcards Order : WebSocket URLs
    Or explicitly from :
    Security  ››  Application Security : URLs : Allowed URLs : Allowed WebSocket URLs
    Hope it helps
    Waiting for your feedback
