Writing Client-Cert info into Header - irule with strange behavior
I have an inherited a BIG-IP and I'm facing a problem with an irule that is implemented there.
The important part is this:
when HTTP_REQUEST priority 200 {
create HTTP headers with ssl cert infos
set dn [ X509::issuer $cert ]
Split DN into Parts
set parts [ split $dn {,} ]
Fill array with the different parts (O=, OU=, ...)
foreach part $parts {
set thispart [ split $part {=} ]
if { [ llength $thispart ] == 2 } {
set dnparts([lindex $thispart 0 ]) [ lindex $thispart 1 ]
Insert the neccessary headers from the DN
HTTP::header insert "SSL_CLIENT_I_DN" $dn
foreach {part myvar} {
{C} {SSL_CLIENT_I_DN_C}
{CN} {SSL_CLIENT_I_DN_CN}
{O} {SSL_CLIENT_I_DN_O}
{OU} {SSL_CLIENT_I_DN_OU}
if { [info exists dnparts($part) ] } {
HTTP::header insert "$myvar" "$dnparts($part)"
So - the irule should read the issuer information and put it in such a format into HTTP headers:
SSL_CLIENT_I_DN: C=DE, O=Test-Organisation, OU=Test-OU, CN=Test-CN
SSL_CLIENT_I_DN_C: DE SSL_CLIENT_I_DN_CN: Test-CN SSL_CLIENT_I_DN_O: Test-Organisation SSL_CLIENT_I_DN_OU: Test-OUNow the application admin reported, that these headers are not sent properly. I activated a logging irule and I can see that for some requests (it seems the initial ones) the format is OK. But for the requests later, the behavior changes. In the log I can only see the first 2 lines repeating constantly:
SSL_CLIENT_I_DN_C: DE SSL_CLIENT_I_DN: C=DE, O=Test-Organisation, OU=Test-OU, CN=Test-CN SSL_CLIENT_I_DN_C: DE SSL_CLIENT_I_DN: C=DE, O=Test-Organisation, OU=Test-OU, CN=Test-CN SSL_CLIENT_I_DN_C: DEAs mentioned, I've inherited this irule from the prior admin and I'm not that deep into TCL. For me, the rule is performed on every HTTP-Request from scratch, so there shouldn't be any difference in the behavior.
Any ideas? 🙂
- nathe
Cirrocumulus
Do you have oneconnect enabled on the VIP? See https://support.f5.com/csp/article/K7208. With oneconnect "the BIG-IP system is able to process each HTTP request individually"
- Anesh
Cirrocumulus
Try the below code:
set parts [ split $dn {,} ] set country [lindex $parts 0] set x [string range $country 2 end] HTTP::header insert "SSL_CLIENT_I_DN_C" $x set org [lindex $parts 1] set y [string range $org 2 end] HTTP::header insert "SSL_CLIENT_I_DN_O" $y set unit [lindex $parts 2] set z [string range $unit 3 end] HTTP::header insert "SSL_CLIENT_I_DN_OU" $z set cname [lindex $parts 3] set a [string range $cname 3 end] HTTP::header insert "SSL_CLIENT_I_DN_CN" $a HTTP::header insert "SSL_CLIENT_I_DN" $dn - am_gli
Altostratus
No, none applied.
- nathe
Cirrocumulus
I would certainly test this, perhaps using the 255.255.255 255 mask.
- am_gli
Altostratus
Figured it out - it was an issue with the space behind the comma.
So "SSL_CLIENT_I_DN: C=DE, O=Test-Organisation, OU=Test-OU, CN=Test-CN" was split to an array but, with leading spaces:
"C|AT" " O|Test...." " OU|Test..." etc.So in this part:
foreach {part myvar} { {C} {SSL_CLIENT_I_DN_C} {CN} {SSL_CLIENT_I_DN_CN} {O} {SSL_CLIENT_I_DN_O} {OU} {SSL_CLIENT_I_DN_OU}the only line that was readable from the array was C, all other didn't match because of the space.
- stan_piron
Cumulonimbus
I already had such issue. there might be another issue, if CN contains a comma (with backslash before), split command may cause an issue. I used following code to convert comma to | except if comma is backslashed:
array set dnparts [split [string map [list "\\," "," " , " "|" " ," "|" ", " "|"] $dn] "|="]this command already create the array.
your code become:
when HTTP_REQUEST priority 200 { ... create HTTP headers with ssl cert infos set dn [ X509::issuer $cert ] Split DN into Parts array set dnparts [split [string map [list "\\," "," " , " "|" " ," "|" ", " "|"] $dn] "|="] Insert the neccessary headers from the DN HTTP::header insert "SSL_CLIENT_I_DN" "\"$dn\"" foreach field [array names dnparts] { HTTP::header insert "SSL_CLIENT_I_DN_$field" "\"$dnparts($field)\"" } }
