ScottR_143804's avatar
ScottR_143804
Feb 11, 2014
Websense Proxies in same pool as servers - Unable to browse through Proxies
I have a single subnet for all of my pool nodes, 172.31.102.128/25 and in this network I have a few servers and also my Websense Proxy servers.
When the pool servers access the proxy via the virtual server IP, 172.31.102.9/25, they cannot get out. I would assume that the traffic goes in via the VS IP but the communication from the proxy to the originating host is then direct within the 172.31.102.128/25 network and not out from the VS 172.31.102.9 IP.
How can I force this traffic to go back through the F5 and route back to the host making the original request?
  • Have you verified that traffic is actually getting to the other side of the proxy? If so, have you tried applying a SNAT to the virtual server?
  • I ran a trace and found that the issue only appears when using a proxy.pac file. With Websense they use port 8083. The trace shows the file being requested via the VS IP, but then there is a direct communication between the proxy and the pool host that requested the file. It's not being sent back from the VS IP.
    If I tell IE to use the 172.31.102.9 : 8080 manually this works just fine.
  • As Kevin says, applying SNAT to your virtual server should fix this issue.
    • ScottR_143804's avatar
      ScottR_143804
      Can you give me an example of what I need to do to accomplish this?
    • Cory_50405's avatar
      Cory_50405
      Icon for Noctilucent rankNoctilucent
      If you navigate to your virtual server configuration in the GUI and scroll to the bottom, the 'SNAT Pool' configuration item will be there. If you want to set a specific NAT address, you can build a SNAT pool and assign it here, or just use Auto Map. Generally Auto Map will meet your needs. After assigning Auto Map to your SNAT, try your connection again.
