snoonanCLG's avatar
snoonanCLG
Aug 13, 2026
DoS Captcha Preview Not showing
Hello All,
I am seeing an issue trying to preview the DoS Captcha. When I press show, a blank pop-up appears.
In the dev tools I can see the following error in the console:
dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1332 Uncaught TypeError: Cannot read properties of undefined (reading 'contentDocument') at show_captcha_response (dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1332:59) at HTMLInputElement.onclick (dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1720:132) dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1332 Uncaught TypeError: Cannot read properties of undefined (reading 'contentDocument') at show_captcha_response (dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1332:59) at HTMLInputElement.onclick (dos_profile_properties.php?mode=edit&profile=/Common/_ddos_policy:1720:132)
Has anyone seen this issue before or know how to resolve?
We are running asm version 17.5.1.3
  • Hi snoonanCLG​ ,
    Hope you will be doing fine.
    Here are my 2 preliminary observations.
    =======Observation 1========
    Have you tested the CAPTCHA preview using both Default and Custom response types?
    Please navigate to:
    Security → DoS Protection → Protection Profiles → → Application Security → CAPTCHA Settings
    For both First Response Type and Failure Response Type, temporarily change the setting from Custom to Default and click Show.
    If the preview displays correctly with the Default response but remains blank with the Custom response, this would indicate that the CAPTCHA engine itself is functioning properly and the issue is likely related to the custom CAPTCHA HTML/template configuration.
    F5 documents that custom CAPTCHA response bodies utilize HTML and support %DOSL7.captcha.*% variables, so it would be worth reviewing the custom response page for any formatting, syntax, or variable-related issues.
    If both Default and Custom previews are blank, then we may need to investigate a broader GUI, browser, or software-related issue rather than the custom template itself.
    As an F5 ASM engineer, I would consider this one of the highest-value isolation tests because it immediately tells you whether you're debugging the CAPTCHA engine or the custom CAPTCHA page.
    ======Observation 2========
    Could you please help verify whether the issue is browser-specific?
    Since the exception appears to be occurring within the BIG-IP Configuration Utility JavaScript, it would be helpful to test the CAPTCHA preview using different supported browsers and browser modes.
    Please try the following:
    Google Chrome
    Microsoft Edge
    Mozilla Firefox
    Incognito/Private browsing mode
    Clear the browser cache before testing, if possible
    Based on the error related to contentDocument, I would specifically recommend comparing the behavior between Chrome/Edge and Firefox.
    For example:
    If the CAPTCHA preview is blank in Firefox but displays correctly in Chrome or Edge, this may indicate a browser compatibility or Configuration Utility UI rendering issue rather than a problem with the ASM/AWAF CAPTCHA engine itself.
    If the behavior is consistent across all browsers, we can continue investigating other potential causes.
    Additionally, F5's 17.5.1.3 compatibility documentation lists supported Configuration Utility browsers, including:
    Firefox 140+
    Chrome 138+
    Edge 137+
    Could you please share the results of the above tests, along with the browser versions used and any screenshots if available? This will help us narrow down the root cause and determine the next troubleshooting steps.
    Along with the above 2 observations checks,
    Could you please verify the DoS profile configuration from the tmsh command line to ensure the profile configuration is healthy and to identify any CAPTCHA-related settings that may be contributing to the issue?
    Please execute the following commands and share the output:
    1. Review the Complete DoS Profile Configuration
    tmsh list security dos profile /Common/_ddos_policy all-properties
    If the output is too large, please focus on the CAPTCHA-related configuration using:
    2. Inspect CAPTCHA-Specific Configuration
    tmsh list security dos profile /Common/_ddos_policy | grep -i -A20 -B10 captcha
    3. Check for Custom CAPTCHA Response Configuration
    tmsh list security dos profile /Common/_ddos_policy one-line | grep -i captcha
    These commands will help us determine:
    Whether CAPTCHA is configured as expected within the DoS profile
    If any custom CAPTCHA response pages are configured
    Whether there are any unusual or unexpected CAPTCHA-related settings in the profile configuration
    If the issue is related to the profile configuration itself rather than the GUI preview functionality
    Once you have collected the outputs, please share them for review. The exact information returned will depend on how the profile has been configured, but it should provide valuable insight into the current CAPTCHA configuration and help guide the next steps in troubleshooting.
    • snoonanCLG's avatar
      snoonanCLG
      Hello, unfortunately the issue occurs both for the default and also custom responses.
      I have tested in compatible versions of Chrome and Edge. Interestingly within the WAF policy I can view the CAPTCHA previews, it is just the DOS specific ones that load up blank.
      Here is the output from the CLI
      [api-status-warning] security/dos/profile, properties : deprecated : application/bot-signatures.categories, application/prot ection
      security dos profile _ddos_policy { app-service none application { _ddos _policy { bot-signatures { categories { "DOS Tool" { action block } "E-Mail Collector" { action block } "Exploit Tool" { act ion block } "Network Scanner" { action block } "Search Engine" { action report } "Spam Bot" { action block } "Vulnerability Scanner" { action block } "Web Spider" { action block } "Webserver Stress Tool" { action block } Spyware { action block } } } captcha-response { failure { body "You have entered an invalid answer for the question. Please, try again.
      %DOSL7.captcha.image% %DOSL7.captcha.audio% %DOSL7.captcha.change%
      %DOSL7.captcha.solution%
      %DOSL7.captcha.submit%
      Your support ID is: %DOSL7.captcha.support_id%." } first { body "This question is for testing whether you are a human visito r and to prevent automated spam submission.
      Your support ID is: %DOSL7.captcha.support_id%." } } heavy-urls { protection disabled } stress-based { behavioral { dos-dete ction enabled signatures enabled } ip-captcha-challenge enabled ip-rate-limiting disabled mode blocking thresholds-mode auto matic url-rate-limiting disabled } tps-based { ip-captcha-challenge enabled ip-rate-limiting disabled thresholds-mode automa tic url-rate-limiting disabled } } }
