Miguel_1400's avatar
Miguel_1400
Nov 14, 2023
VPN Machine tunnel + VPAN alwaysON + location awarness
Hello,
I actually use the F5 Big-IP edge client with the always connected mode and I would to be able to do an remote assistance or that the user can change his password with the VPN so I m configuring the Machine tunnel mode.
The Machine tunnel works, I m able to request an remote assitance and the user can change her password but my problem is that when I m login on Windows the Big-Ip edge client doesn't switch so I m still connected with the Machine tunnel. I'm connected to the LAN through the Machine tunnel, so the big-ip edge client doesn't switch...
How I can obliged the big-ip edge client to switch once the user is loged on the sessin Windows ?
Hope my explanation is clear
Regards,
Miguel
