F5_Jeff's avatar
F5_Jeff
Icon for Cirrus rankCirrus
Sep 27, 2017
Viprion without vCMP to Viprion with vCMP
hey everyone!
We have a viprion in production right now (vCMP not provisioned) and we are planning on activating it. We will be creating the Guests (2 specifically).
My question is, is it possible to load the UCS of the current configuration (without vCMP) to the Guests that we will be creating?
if possible, am i going to load the full UCS because from what I know, network configurations are configured in the Host level. How should we approach this scenario?
Thank you for responding!
  • You will need to configure manually the host and guests. As you already said, some configuration will go to the host and other to the guests.
    After that, you can load some part of the configuration.
    Use either the UCS or SCF to cut the shared configuration (like vs/pools/etc...), then use the merge command to load that.
    tmsh load sys config merge
    tmsh save sys config partitions all
