Viprion, vCMP with 2 primary blade
I have a vCMP in Viprion with 2 blades.
After changing vCMP mode, Isolated to Bridge. The secondaray blade missed the change and keep the old IP management address. I changed manually the config on secondary blade and after some reboot the CLuster works fine.
But if I reboot the vCMP from the chassis, Provision and Deploy, the blades will never come up because all blade wants the primary status.
Aug 26 13:59:50 slot1/biip_test1 notice clusterd[5835]: 013a0015:5: Blade 1 quorum state increasing from QUORUM to RUNNING. Aug 26 13:59:50 slot1/biip_test1 notice clusterd[5835]: 013a0020:5: Blade 1 turned Green: Run Aug 26 13:59:50 slot2/biip_test1 warning clusterd[5355]: 013a0016:4: Blade 2 quorum state decreasing from RUNNING to QUORUM. Aug 26 13:59:50 slot1/biip_test1 notice mcpd[5833]: 010713c1:5: Initial management network proposals triggered (slot's cluster member turning green). Aug 26 13:59:50 slot1/biip_test1 notice mcpd[5833]: 010713c2:5: No new proposal values detected. Aug 26 13:59:50 slot1/biip_test1 notice zxfrd[6919]: 01531300:5: Cluster status changing from Primary to Primary (Single slot). Aug 26 13:59:51 slot2/biip_test1 notice clusterd[5355]: 013a0015:5: Blade 2 quorum state increasing from QUORUM to RUNNING. Aug 26 13:59:51 slot1/biip_test1 warning clusterd[5835]: 013a0016:4: Blade 1 quorum state decreasing from RUNNING to QUORUM. Aug 26 13:59:51 slot1/biip_test1 notice clusterd[5835]: 013a0019:5: Blade 1 turned Yellow: Quorum Aug 26 13:59:51 slot1/biip_test1 notice zxfrd[6919]: 01531300:5: Cluster status changing from Primary (Single slot) to Primary. Aug 26 13:59:51 slot2/biip_test1 notice logger: /usr/bin/tmipsecd --tmmcount 2 ==> /usr/bin/bigstart stop racoon Aug 26 13:59:51 slot1/biip_test1 notice clusterd[5835]: 013a0015:5: Blade 1 quorum state increasing from QUORUM to RUNNING. Aug 26 13:59:51 slot1/biip_test1 notice clusterd[5835]: 013a0020:5: Blade 1 turned Green: Run Aug 26 13:59:51 slot2/biip_test1 warning clusterd[5355]: 013a0016:4: Blade 2 quorum state decreasing from RUNNING to QUORUM. Aug 26 13:59:51 slot1/biip_test1 notice mcpd[5833]: 010713c1:5: Initial management network proposals triggered (slot's cluster member turning green). Aug 26 13:59:51 slot1/biip_test1 notice mcpd[5833]: 010713c2:5: No new proposal values detected. Aug 26 13:59:51 slot1/biip_test1 notice zxfrd[6919]: 01531300:5: Cluster status changing from Primary to Primary (Single slot). Aug 26 13:59:52 slot2/biip_test1 notice clusterd[5355]: 013a0015:5: Blade 2 quorum state increasing from QUORUM to RUNNING. Aug 26 13:59:52 slot1/biip_test1 warning clusterd[5835]: 013a0016:4: Blade 1 quorum state decreasing from RUNNING to QUORUM. Aug 26 13:59:52 slot1/biip_test1 notice clusterd[5835]: 013a0019:5: Blade 1 turned Yellow: Quorum
The vCMP can come up if I reboot 1 blade during the startup. Do you know where can I set the primary list?
Regards
Daniel
