damian_19221
Aug 06, 2015VIPRION default Management Address
Hi all,
While performing an upgrade to 11.6.0, a partition with an older version was activated and according to SOL14704 this means the default configuration appears to have loaded. We can no longer access the VIPRION on the configured mgmt address.
To recover the system, I'm trying to connect to the default management IP, but 192.168.1.245 doesn't work. Is there something else I could use?
- damian_19221
No longer needed... we restarted the chassis and the previous config loaded successfully. Phew! Oh to return to the days of an LCD panel showing the address :)
- amolari
a LCD panel is available for the Viprion. Optional.
