rmd1023's avatar
rmd1023
9 years ago
Using the same 3rd party certificate for two devices in a device group?
I currently use self-signed certificates on my cluster of LTMs running 11.5.3. I would like to install 3rd party certificates.
If I generate a certificate that has subject alternative names that include the individual hostnames for the two devices as well as the name of the floating IP, can I apply that certificate to both devices? Or will the device group sync have a problem with sharing a cluster with a device that has the same certificate?
So if my two devices are "ltm-1.example.com" and "ltm-2.example.com" and the name of the floating IP is "ltm-active.example.com", I'd have a certificate for ltm-active.example.com with ltm-1.example.com and ltm-2.example.com as SANs and I would install the same cert/key pair on both devices.
Thanks!
  • Kevin_K_51432's avatar
    Kevin_K_51432
    Historic F5 Account
    Greetings!
    This article offers some background on the various device certificates. In short, the DSC certificates are different than the Configuration utility certificates. I believe (hope) you are going to be installing the certificate to access the Configuration utility?
    https://support.f5.com/csp/article/K15664
    Hope this helps! Kevin
