rmd1023's avatar
rmd1023
Jun 02, 2017
Using the same 3rd party certificate for two devices in a device group?
I currently use self-signed certificates on my cluster of LTMs running 11.5.3. I would like to install 3rd party certificates.
If I generate a certificate that has subject alternative names that include the individual hostnames for the two devices as well as the name of the floating IP, can I apply that certificate to both devices? Or will the device group sync have a problem with sharing a cluster with a device that has the same certificate?
So if my two devices are "ltm-1.example.com" and "ltm-2.example.com" and the name of the floating IP is "ltm-active.example.com", I'd have a certificate for ltm-active.example.com with ltm-1.example.com and ltm-2.example.com as SANs and I would install the same cert/key pair on both devices.
Thanks!
