hjadams123_1054's avatar
hjadams123_1054
Dec 15, 2011
Using IRules to Direct Remote Desktop Traffic?
Hello and Good Afternoon DevCentral... We use our LTM 6400 primarily to load balance our customers on Windows 2003\2008 Terminal Servers. Customers connect over the internet using the standard TCP 3389 to connect to one of many virtual servers that represent terminal services farms we have internal to our network. I am wondering if anyone has any experience in using irules to direct inbound terminal services connections to a particular pool based on the FQDN that used to connect. For instance.... computer.termserver.com is the FQDN the customer uses to connect to the terminal services farm. computer.termserver.com resolves to an public IP we own, that we NAT to a virtual ip\server we have configured on the LTM 6400. Is the LTM capable in anyway of being "aware" the external RDP connection is using computer.termserver.com as the address, so we can possibly direct the inbound terminal services connection to a particular pool? I know alot of irules seem to be based on HTTP\HTTPS traffic, don't know if there are any options for the Remote Desktop Protocol. Thanks for any help you can provide...
  • Something like this could work?!
    when CLIENT_ACCEPTED {
     if {[TCP::local_port] == 3389 and [HTTP:host] == "computer.termserver.com" }{
        pool rdp_servers
        pool default
  • Something like this could work?! i do not think so. rdp is not http, so HTTP::host is not valid.
    i am not aware of fqdn in rdp packet or maybe i missed it.
  • I've done something similar for SQL traffic and hostnames so you would need to create a VS listening on port 3389 and then it should work?
      if { [matchclass [IP::remote_addr] equals $::Wip_Server] } {
        pool SQL-Wip
      } elseif { [matchclass [IP::remote_addr] equals $::UAT_Server] } {
        pool SQL-UAT
      } elseif { [matchclass [IP::remote_addr] equals $::Live_Servers] } {
    although instead of re-directing traffic based on a tcp port you would just need to create datagroups with the IP addresses of the clients connecting via RDP and then the VS will only re-direct traffic to pools going to port 3389?
    So you would create seperate VS for the different terminal server hostnames?
    Pav
        pool SQL-Live
        pool SQL-Wip
        pool SQL-UAT
    Pav
    pool SQL-Live
        pool SQL-Wip
        pool SQL-UAT
    Pav
    pool SQL-Live
        pool SQL-Wip
        pool SQL-UAT
    Pav
    pool SQL-Live
