Albert__Tase_70
Jun 29, 2011using Irule to manage and control ssl client profiles
Hello
Is it possible to use an Irule to match based on https url if it matches say https://axc.com assign ssl client profile A then load balnce to a spefic pool ?
and in same Irule same vip if it matches https://axb.com assign it ssl client profile B then load balance to a different pool ?
Al
- Colin_Walker_12Historic F5 AccountTechnically speaking you won't be able to do anything with traffic inspection until the traffic is decrypted anyway, meaning that a client profile will have been enforced. You're able to switch profiles at that point, if you want, with SSL::renegotiate, but you can't do that before the decryption happens. And yes, you can certainly direct to different pools based on URL once the traffic is decrypted.
Colin - Valentine_96813
Here are two different ways I do it. The first is based in a single VS and iRule doing different redirects to pools. The second is redirecting to another VS. You can use this second method if you wanted do something like apply client certs as in this example. You'll have to strip out what you dont need, I was OTR when I posted this.
First:
rule rule_www.abc.com_443 {
if { [string tolower [HTTP::uri]] contains "test" } {
SSL::disable serverside
pool pool_www.abc.com_80
} elseif { [string tolower [HTTP::uri]] eq "/" } {
HTTP::redirect "https://www.abc.com/home.aspx"
} elseif { [string tolower [HTTP::uri]] starts_with "/def" } {
SSL::enable serverside
pool pool_www.abc.com_doc_443
snat none
virtual vs_www.abc.com_443-SERVERSSL
} elseif { [string tolower [HTTP::uri]] contains "myweb" } {
pool pool_www.abc.com_myweb_443
snat none
} elseif { [string tolower [HTTP::uri]] starts_with "/files/" } {
set uri [findstr [HTTP::uri] "/Files/" 10 ]
HTTP::uri "/abc/$uri"
log local0. "[HTTP::uri] matched /abc$uri"
pool pool_www.abc.com_files_80
Second:
rule rule_alpha.bravo.com_443 {
if { [HTTP::uri] starts_with "/abcd" } {
set exact_name "https://[HTTP::host]:444[HTTP::uri]"
HTTP::redirect "https://[HTTP::host]:444[HTTP::uri]"
log local0. "got here $exact_name"
} elseif { ([HTTP::uri] eq "/")
or ([HTTP::uri] starts_with "/test.htm")
or ([HTTP::uri] starts_with "/efg/")
or ([HTTP::uri] starts_with "/hij/")
or ([HTTP::uri] starts_with "/klm/")
or ([HTTP::uri] starts_with "/nop/") } {
allow if matches the above otherwise reject per below
else {
reject
rule rule_alpha.bravo.com_444 {
when CLIENTSSL_CLIENTCERT {
HTTP::release
if { [SSL::cert count] < 1 } {
reject
} - hoolio
Until all commonly used OS's and browsers support TLS server name indication (SNI), this won't be practical to implement on LTM or any network device.
Aaron - hoolio
