royster_128009's avatar
royster_128009
22 years ago
Using iControl with Health Monitors
I have been using BIGIPs at our company for several of our customers for a couple of years.
I have written custom monitors using perl before testing appilication availability using simple curl commands. Whilst this has worked previously for services that were simply UP or DOWN, We now have a new customer onboard that would like a much more fine grained control over server availability and BIGIP management of them.
The requirement is for BIGIP to poll the webserver which will come back with 1 of 3 responses.
- 'OK' indicates that the service is running normally and requests can be
routed to it.
- 'NoNew' indicates that BigIP should continue current connections to that
service but not allocate any new connections to it.
- 'NotOK' indicates that the service is not functioning, and BigIP should
route all requests to an alternate server.
Having spoken to F5 support they tell me that iControl is the way to go since the 'Enable Connections', which is the control which will allow exisitng sessions to drain away, can only be set through manual intervention. I need this value to be set automatically from within the script depending on the outcome of the health check.
I've not used iControl at all and would interested in any feedback and how I could go about implimenting this using perl.
  • Assuming you are running BIG-IP v4.5 you should have the necessary perl modules to execute iControl methods. The SDK includes sample code in for interacting with nodes including querying the states. The specific methods you are looking for are set_state() and set_availability() located in the ITCMLocalLB::Node namespace.
    The only possible issue with using iControl on the box is that the perl script will have to have the local web username and password included which could be considered a security issue. The scenarios we generally see our customers using are
    1. External Montoring
    Basically this is using their own monitoring applications and making node provisioning method calls from the external application.
    2. Server self monitoring
    In this case logic is put on the webservers so they can report their own health to the BIG-IP. This is beneficial as the server has more information about it's "health" than any outside entity could. The downside to this approach is that custom code needs to be developed and maintained on the servers.
    So, with that being said, if you (and your customers) are comfortable with putting the user credentials in the script it should be very straightforward to develop this script.
    The following methods would be used:
     // For draining connections to a node server (ie. 10.10.10.10:80)
     void ITCMLocalLB::Node::set_availability(
         in IPPortDefinition[] node_defs,
         in AvailabilityState state
     // For stopping connectivity to a node server (ie. 10.10.10.10:80)
     void ITCMLocalLB::Node::set_state(
         in EnabledState state
    Here's some code segments that might help in developing the code (forgive me for any typos as I'm writing this on the fly).
     use SOAP::Lite;
     $sBIGIPAddress = "";   Enter local BIG-IP address here
     $sUID = "";  Enter Local Username here
     $sPWD = "";  Enter Local Password here
     $sNodeIP = "";  Set to nodes ip address
     $sNodePort = "";  Set to node's port
     $node_definition = { address => $sNodeIP, port => $sNodePort };
     $AVAILABILITY_UP = 2;
     $AVAILABILITY_DOWN = 1;
     $STATE_DISABLED = 0;
     $STATE_ENABLED = 1;
     sub SOAP::Transport::HTTP::Client::get_basic_credentials
         return "$sUID" => "$sPWD";
     $LocalLBNode = SOAP::Lite
         -> url('urn:iControl:ITCMLocalLB/Node')
         -> readable(1)
         -> proxy('https://$sBIGIPAddress/iControl/iControlPortal.cgi');
      poll webserver for status code
     $sResponse = &pollWebServer();
      perform node action based on status code
     if ( "OK" eq $sResponse )
         $LocalLBNode->set_state
             SOAP::Data->name ( node_defs => [$node_definition] ),
             SOAP::Data->name ( state => $STATE_ENABLED )
           Check for fault
         $LocalLBNode->set_availability
             SOAP::Data->name ( state => $AVAILABILITY_UP )
           Check for fault
     elsif ( "NoNew" eq $sResponse )
          "drain" connections
             SOAP::Data->name ( state => $AVAILABILITY_DOWN )
     elsif ( "NotOK" eq $sResponse )
          stop traffic
             SOAP::Data->name ( state => $STATE_DISABLED )
           Check for fault
    Good luck and let us know how things go...
    -Joe
  • Hi,
    I'm getting the following errors whilst trying to renable a node
    the section of the code:
     elsif ( $sResponse eq "OK" )
     print "OK\n";
             SOAP::Data->name ( state => $AVAILABILITY_ENABLED )
    Produces this error:
    >8001
    >10.10.11.3
    >8
    ITCMCommon::InvalidArgument Exception caught on ITCMLocalLB::Node::set_availability()!
  • I've updated the original posting with code that should work. I appologize for the incorrectness in the original post. The correct values for Node::set_availability are AVAILABILITY_UP (2) and AVAILABILITY_DOWN (1). (not AVAILABILITY_ENABLED AND AVAILABILITY_DISABLED as I previously mentioned.
    -Joe
  • I now have a working script, however one of the downsides is that each time the EAV is now invoked, regardless of the status, a log is made which is making for numerous duplicate entries because of the iControl
    $AVAILABILITY_UP node actions.
    Oct 27 17:30:47 BigIP01 last message repeated 50 times
    Oct 27 17:20:50 BigIP01 last message repeated 50 times
    Oct 27 17:10:51 BigIP01 last message repeated 10 times
    Oct 27 17:08:52 BigIP01 last message repeated 2 times
    Oct 27 17:08:28 BigIP01 bigd: Service detected UP (EAV) for 10.10.11.3:8001
    Is there anyway round this?
  • You could modify the script to query the state/availability of the node and only make the iControl call if the state/availbility has changed. That will result in an additional call for conditions when the state changes, but will result in only a query when the state is the same. Queries do not result in log messages being generated so you will only get log entries for the conditions when state changed.
    -Joe
  • Hello.
    Below is a copy of the script that we are currently testing with.
    A few notes.
    Firstly, the 'NoNew' or 'Draining' functionality is only as good as the persistence model you use. We monitor two different types of pools, http and https. The https persistence used SSL ID and for http - we inserted a cookie with a zero value for expiration so it was more session based. It seems to work very well.
    Also for 'NoNew' we did a $STATE_DISABLED coupled with a $AVAILABILITY_UP in order to get it to work.
    Comments welcome.
     !/usr/bin/perl
      BIG-IP Script to check App Status using iControl /
      R.Dimbleby / Joe of F5 20/10/03
     use strict;
     use SOAP::Lite + trace => qw(method debug);
     use SOAP::Lite;
     my $programname = "web01_http_8001_checker";
     if ($programname eq '') {
         die "Bad data in program name\n"
      Process ID and file where it's to be stored.  The format
      is significant.
     my $pidfile = "/var/run/$programname.pid";
     my $pid = "$$";
      Maintenence.  Clean up any existing EAV.
     if (-f $pidfile ) {
         open(PID, "<$pidfile");
         my $pid = ; chomp $pid; $pid =~ m/^(\d+)$/; $pid = $1;
         close(PID);
         kill -9, $pid;
         unlink($pidfile);
      Create a new maintenence file.
     open(PID, ">$pidfile");
     print PID $pid, "\n";
     close(PID);
     my $sBIGIPAddress = "10.10.5.2";   Enter local BIG-IP address here
     my $sUID = "";  Enter Local Username here
     my $sPWD = "";  Enter Local Password here
     my $sNodeIP = "10.10.11.3";  Set to nodes ip address
     my $sNodePort = "8001";  Set to node's port
     my $curl = "/usr/local/bin/curl";
     my $timeout = 10;
     my $output = "/usr/local/lib/pingers/output_$sNodeIP\_$sNodePort";
     my $url = "http://$sNodeIP:$sNodePort/getstatus.jsp";
     my $node_definition = { address => $sNodeIP, port => $sNodePort };
     my $AVAILABILITY_ENABLED = 8;
     my $AVAILABILITY_DISABLED = 9;
     my $AVAILABILITY_DOWN = 1;
     my $AVAILABILITY_UP = 2;
     my $STATE_DISABLED = 0;
     my $STATE_ENABLED = 1;
     my $LocalLBNode = SOAP::Lite
         -> uri('urn:iControl:ITCMLocalLB/Node')
         -> readable(1)
         -> proxy("https://$sBIGIPAddress/iControl/iControlPortal.cgi");
     my $sResponse = &pollWebServer();
      If nothing at all
     if ( -z $output )
     {  stop traffic
     elsif ( $sResponse eq "NotOK" )
          stop traffic
     print "UP\n";
     checkOKState();
     elsif ( $sResponse eq "NoNew" )
          "drain" connections
             print "No New\n";
      pollWebServer
      Get status from Webserver
     sub pollWebServer {
             my($returnval)="";
             my $line="";
              For SSL use system("$curl -m $timeout -E BigIPMonitor.pem $url > $output");
             system("$curl -m $timeout $url > $output");
             open(fd,"/usr/local/lib/pingers/output_$sNodeIP\_$sNodePort");
             my @lines=;
             foreach $line (@lines) {
                     if ($line =~ /\bNotOK\b/) { $returnval="NotOK"; }
                     if ($line =~ /\bOK\b/) { $returnval="OK"; }
                     if ($line =~ /NoNew/) { $returnval="NoNew"; }
             close fd;
             return($returnval);
      checkOKState
      Is the node already UP
     sub checkOKState {
             my $soap_response =
                     $LocalLBNode->get_availability
                         SOAP::Data->name ( node_def => $node_definition )
                             my $result = $soap_response->result;
                             print "Node $sNodeIP:$sNodePort availability: ";
                             if ( 0 == $result )
                                     print "UNCHECKED\n";
                             elsif ( 1 == $result )
                                     print "DOWN\n";
                              Bring back UP after failure
                             elsif ( 2 == $result )
                                     print "UP\n";
                             elsif ( 4 == $result )
                                     print "FORCED DOWN\n";
                             elsif ( 9 == $result )
                             print "DISABLED\n";
                              Bring back UP after NoNew
