luyenntk50db's avatar
luyenntk50db
5 years ago
Using an iRule to display a maintenance page when the pool is down
I have configured to redirect Virtual server to maintenance page when all pool member down.
I have configured below guide:
https://support.f5.com/csp/article/K14702105
When i used irule below, Irule has completed configuration.
   if { [active_members [LB::server pool]] == 0 } {
     HTTP::respond 200 content "
      <html>
         <head>
            <title>Maintenance Page</title>
         </head>
         <body>
            We are sorry, but the site you are looking for is temporarily out of service.
            If you feel you have reached this page in error, please try again.
         </body>
      </html>
But, when I edited as below, irule has not change:
   <html>
     <head>
     </head>
     <body>
     <article>
       <center><h1 style="color: #000;">
      Xin lỗi quý vị, hệ thống đang được bảo trì. Xin quý vị quay lại sau khi bảo trì hoàn tất.</h1> <center>
      <div>
    <center><h1 style="color: #000;">Xin trân trọng cảm ơn!.<p></p><center>
    </center></h1></center></div>
     <article>
     </body>
   </html>
Errors as below:
Pls guide me!
  • Hi
    Try changing the " " to group the HTML to { } braces instead as per the error. Suspect the " in the style lines are causing a conflict.
       HTTP::respond 200 content {
       <html>
         <head>
         </head>
         <body>
         <article>
          <div>
         <article>
         </body>
       </html>
  • OK - so you could either move your html code to a variable and then make a call to it like this
    when RULE_INIT {
    set static::sorry_code {
    <html>
         <head>
         </head>
         <body>
         <article>
          <div>
         <article>
         </body>
       </html>
       HTTP::respond 200 content $static::sorry_page
    ...or you could try moving the html code to an iFile - https://clouddocs.f5.com/api/irules/iFile.html - if there are any strange characters in the html code that is causing a conflict then this method should resolve these issues
