jay_41157's avatar
jay_41157
Aug 18, 2008
use status of default pool as the monitor for pool2
Hi
VS defined with a default pool
--> irule
--> if something
--> default pool
else
--> pool b;
We have run into a problem with the above in the past..
If default pool is down, and pool b was up then the vs stays up at the GTM level, so what would be a good way to make sure that the vS is marked down when the default pool is down and up when the default pool is up.
We do not care to check the status of pool b.
Monitors:
Default pool members: For the default pool we check /heartbeat on the servers and expect a response of 0
Pool b: I need the status to be in sync with default pool.
Will this approach work?
1. custom monitor that checks /heartbeat for the vip (in alias address) of the VS that the pool is a member of? I am unsure if this option will work?
2. can something be done with using the number of active pool members in default pool?
jay
  • I think in normal scenerio if default pool is down LTM shows Virtual server down too. In GTM what is the ECV ?
