murali_125469's avatar
murali_125469
Apr 19, 2018
Use cases for Layer 2 forwarding Virtual servers?
Hello Everyone !
I understood what is Layer2 forwarding VS & how it works but could someone explain what are the use case scenarios for Layer2 Forwarding VS ? Has anyone deployed this ?
Thank You
Murali.
  • Have you looked at Lori MacVittie's (F5) article, Back to Basics: The Many Modes of Proxies? It provides some information on L2 Forwarding Virtual Servers. Basically, it is not uncommon for a BIG-IP system to be placed in a network location where it sits in the path between two existing networks. As a default-deny system, any traffic that is not explicitly allowed by the BIG-IP system's configuration is denied. Therefore, if access is needed between networks where the BIG-IP system is in the path, a forwarding virtual server provides an ideal solution. A forwarding virtual server essentially changes your BIG-IP system from full-proxy mode to packet-by-packet proxy mode, at least for the traffic the forwarding virtual server processes:
    The BIG-IP system provides forwarding services in two ways:
    • For simple packet forwarding, where the destination is not based on a pooled resource but simply on a routing table, a forwarding IP virtual server turns the BIG-IP full proxy into a packet layer forwarder.
    • For situations where a proxy should be used to bridge two different collision domains, a layer 2 forwarding virtual server can be used, and configured to be an opaque, semi-opaque, or transparent bridge. (From Lori's article.) A forwarding layer 2 virtual server shares the same IP address as a node in an associate VLAN, and is used in conjunction with a VLAN group.
    Does this help?
  • i have gone through the article but i didn't get the where this can be used ? if it's like a network bridge will the L2 VS forwards the packet based on destination MAC ? i'm not sure how this works.
    Thank You
  • @crodriguez
    Can I ask better way?
    using L2 forwarding.
    using L3 forwarding & change db vlangroup.forwarding.override value false?
    with regards,
