jethro_106302's avatar
jethro_106302
Dec 15, 2008
uri based pool selection and persistence
Hi Folks,
I am rather new to using iRules, and would like some advice for a problem I'm trying to solve.
I want to have an http virtual server, sharing the load on two pools of several members. On the web side, there are two apps working together, 1 under URI /foo and the other under URI /bar. I want to loadbalance requests to /foo on pool A, and requests to /bar on pool B.
Application A (in /foo) expects/sets JSESSIONID cookies , and Application B (in /bar) expects/sets FOOBAZOO cookie. Both Apps send a "Set-Cookie" if there isn't any in the client request, or if the one present is outdated.
As my nodes in my pools aren't able to share any applicative context, I need to make sure a client always gets loadbalanced to the same node once it has an authenticated cookie.
I've been reading the iRules wiki for some time, and had a look at CodeShare as well, from which I borrowed a few lines and ended up with the following iRule :
    if { [HTTP::cookie exists "JSESSIONID"] } {
          persist uie [HTTP::cookie "JSessionID"]
    if { [HTTP::cookie exists "FOOBAZOO"] } {
          persist uie [HTTP::cookie "FOOBAZOO"]
    if { [HTTP::uri] starts_with "/foo" } {
          pool pool_A
    } elseif { [HTTP::uri] starts_with "/bar" } {
          pool pool_B
    } elseif { [HTTP::uri] equals "/" } {
          HTTP::redirect /foo
          pool pool_A
  when HTTP_RESPONSE {
           persist add uie [HTTP::cookie "JSESSIONID"]
On the VS side, it is set to standard profile, has "universal" as persistence profile, and pool_A as the default pool.
any feedback, advice would be much appreciated.
tia,
jerome
  • hoolio's avatar
    hoolio
    Hi Jerome,
    You could probably move the two cookie checks into the respective tests on the URI. If the cookies are set with a path, they should only be sent by the client in a request which starts with that path.
           pool pool_A
           pool pool_B
           HTTP::redirect /foo
           pool pool_A
    Aaron
  • Hey Aaron,
    thanks for the quick answer, I will do as you suggest, it looks more efficient than what I originally posted.
    regards,
    jerome
