Angel_Martinez_
Apr 11, 2013upgrade Soft 9.x to 10.x and upgrade hard from BIGIP6800 to BIGIP6900
Hi
I have to replace a 9.x cluster on 6800 to a new one 10.x on 6900 boxes...
The main problem is that my bigip.conf is too long I is very painfull to adapte it by hand.. so is there any tool for converting bipip.conf for 9.x to 10.x ¿?
Thanks!!!
- insert12_38638
if you do not prefer edit this using notepad++ , then prepare 6900 to same firmware equal to 6800. Copy 6800 UCS to 6900 and the upgrade 6900 to version 10.x.x
This will automatically convert bigip config from 9.x to 10.x.
However there is no issue copying UCS from one platform to another except below one
http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13136.html
/Insert12
