Masoud_pourshab's avatar
Masoud_pourshab
Jul 05, 2018
Updating F5 VIP using requests
Hello all, I am using the following code(only brief) to create VIP and pool. How can update an item in a VIP. For example, how can I change NAT from Autonat to None or how to change VIP IP address? Executing the code with new parameter does not overwrite the current configuration. Thank you
bigip = requests.session()
bigip.auth = (BIGIP_USER, BIGIP_PASS)
bigip.verify = False
bigip.headers.update({'Content-Type': 'application/json'})
bigip.post('%s/ltm/virtual' % BIGIP_URL_BASE, data=json.dumps(payload))
BIGIP_URL_BASE = '' % BIGIP_ADDRESS
create_http_virtual(bigip, VS_NAME, VS_ADDRESS, VS_PORT, POOL_NAME)
  • You must use PATCH instead of POST. See https://devcentral.f5.com/wiki/icontrolrest.icontrolrestuserguide_v1300_3.ashx for details:
    Citation:
    Modifying a resource with PATCH
    Using the PATCH method, you can modify properties of a resource without affecting any other properties.
    To modify an object in the BIG-IP® system configuration, specify the resource in the URI. Do not specify a collection in the URI.
    PATCH https://192.168.25.42/mgmt/tm/pool/~Common~tcb-pool2
    {"member": [{:name":"192.168.25.32:80", "description":"Tertiary web server"}] }
  • Adapted to python requests, it would for example translate to:
    payload = {'description':'modified via REST'}
    bigip.patch(BIGIP_URL_BASE + '/ltm/virtual/~Common~vipname',data=json.dumps(payload))
  • It seems like I can only patch the description. The following works
    payload['description'] = 'test'
    bigip.patch(BIGIP_URL_BASE + '/ltm/virtual/test5-http-virtual_python', data=json.dumps(payload))
    but they did not work
    payload['service port'] = '100'
    payload['service_port'] = '100'
  • There is no property like this. If you plan to change the port, you need to alter the destination property instead. Try issuing an http GET on the same virtual first, then you can see the exact names and values of all properties.
  • tatmotiv if you posted that as an answer the questioned could be flagged as answered now :)
