CGI's avatar
CGI
14 years ago
Updated iAPP for Lync 2010
Hi i was looking for the updated iApp template for Lync 2010, should´nt the template be under the http://devcentral.f5.com/wiki/iApp.CodeShare.ashx under F5 supported iApp templates ?
/regards Craig
  • mikeshimkus_111's avatar
    mikeshimkus_111
    Historic F5 Account
    Hi Craig, the updated Lync iApp is now on the code share page under "F5 Contributed".
    thanks
    Mike
  • In the 3-15 release notes it states SSL and other profiles were removed for access services. Is there a reason for this? Previous versions has SSL profile (and SSL termination) enabled in the iApp.
    - b
  • Michael_Shimku2's avatar
    Michael_Shimku2
    Historic F5 Account
    The SSL and HTTP profiles were removed because although you can provision it on port 443, the Access service does not use HTTP. The previous version of the template was breaking access by applying these profiles to the virtual server.
