UDP 1026 port unreachable and dual active
I recently update two old box to 9.4.8 after updating. found dual active! I tcpdump packet from HA interface,found port unreachable from both side of 1600. from netstat -na udp 0 0 ::ffff:1.1.1.6:1026 ::ffff:1.1.1.5:1026 ESTABLISHED I found 1026 port was established, why reply a icmp port unreachable? I confuse, is there any possible ,there are some wrong in the F5 bigip 1600 internal to udp port 1026. thank you! Tom
- nic1
Did you find resolution to this issue? We are also seeing icmp port unreachable for udp 1026 and encountered a dual active scenario for where a heartbeat should have saved us but does not appear to be properly established. - IanB
Employee
Ensure that port lockdown is not set to none, or that you've not removed 'cap' (numerically 1026) from the default-allow list:
SOL13250: Overview of port lockdown behavior (10.x - 11.x)
