_Mo__2's avatar
_Mo__2
Feb 22, 2019
Trying to load an UCS from an hardware bigip 11.6.2 to a VE 13.1.1 with platform migrate option but it failed with the LACP
Hi Everyone,
I'm struggling with an UCS with LACP configuration and I can't import it in a VE. Here the CLI I used:
tmsh load sys ucs F5_backup.ucs no-license platform-migrate
2019 Feb 22 16:54:15 F5-ISO load_config_files: "/usr/bin/tmsh -n -g load sys config partitions all platform-migrate" - failed. -- Loading schema version: 11.6.2 Loading schema version: 13.1.1 01070687:3: Link Aggregation Control Protocol (LACP) is not supported on this platform. Unexpected Error: Loading configuration process failed. Configuration loading error: high-config-load-failed
Do you any idea how skip the LACP part ?
Thanks a lot
Mo
