Trunk to two separate switches?
Sw1<=>Sw2
g1/6 g1/6
1.1 1.2
LB
On the LB I created trunk 'Trunk_External', with interfaces 1.1 and 1.2, no LACP.
I created VLAN 'External' with Untagged interfaces 'Trunk_External'. And then a self IP with vlan 'External'.
I've tried STP mode pass-through, and STP mode STP, and all interfaces on both switches and LB trunk show forwarding either way, not sure if this how it's supposed to be, I just don't want a bridging loop.
Is that the desired way to do this even though all ports are forwarding? STP info below.
Sw1:
VLAN30
Gi1/0/6 Desg FWD
Po1 Desg FWD
Sw2:
VLAN30
Gi1/0/6 Desg FWD
Po1 Root FWD
LB:
STP MODE stp
+-> STP INSTANCE 0 priority 61440 root bridge B8:BE:BF:E4:90:80 (Sw1)
+-> STP VLAN 0/External +-> STP TRUNK 0/Trunk_External | path cost 20000 priority 128 role root | state forward (forward) link auto not edge
VLAN External tag 30 00:23:E9:09:22:C3 MTU 1500
+-> VLAN MEMBER External/Trunk_External untagged
+-> TRUNK Trunk_External(Id: 2) 00:23:E9:09:22:CF LACP DISABLED members: 2 (2 working)
Thanks!
- nitass
Employee
does the switches support cross-stack etherchannel? if not, i do not think you should create trunk on bigip side.
i guess the switches do not act like one virtual switch. so, can you just assign interface 1.1 and 1.2 to vlan external as untagged? for stp, pass-through mode should be fine. - Matt_70198
Correct no ability to etherchannel the switchports going to the LB.A coworker steered me down the wrong path by saying I need to do this with a trunk and not selecting LACP. I did what you suggested nitass and removed the trunk and added 1.1 and 1.2 to External vlan.
With STP in pass-through I see Sw2 Gi1/0/6 in BLK. With STP enabled on the LB I see 1.1 in FWD and 1.2 in BLK.
During testing I found pass-through doesn't work so well, I shut down 1/6 on Sw1 and instead of Sw2 1/6 going to FWD it went to block loop inconsistent state for some reason, had to shut no shut interface for it to come up.
With LB mode set to STP I shut down Sw1 1/6, 1.1 went to BLK, 1.2 went to FWD, all was good. So in this type of setup STP is preferred vs pass-through.
Thanks for the advice nitass!
