Jim_Schwartzmei's avatar
Jim_Schwartzmei
Dec 21, 2017
Trouble with tmsh command using incorrect route domain
I am trying to automate an SSL CRL update. I have the correct command tmsh modify /sys file ssl-crl testca.crl source-path https://10.11.248.22/web/cert/testca.pem, which is working in a sandbox environment with a single route-domain.
I cannot get this to function in production where there are multiple route-domains. 10.11.248.0/24 is directly connected to the F5 in RD2. I have verified that I am able to curl the path.
rdexec 2 curl -k https://10.11.248.22/web/cert/testca.pem goes out the correct interface and returns the pem file.
However, modify /sys file ssl-crl testca.crl source-path https://10.11.248.22/web/cert/testca.pem, that uses RD 0 interface and this is NOT routeable to the 10.11.248.0/24 network.
I have attempted rdexec 2 tmsh modify /sys file ssl-crl testca.crl source-path https://10.11.248.22/web/cert/testca.pem But that also attempts to connect through the RD 0 interface.
I am stumped on this one. How can I tell the tmsh command modify /sys file ssl-crl to use RD 2?
  • this is not supported currently. it is tracked as ID692064 TMSH: FileObjectCmd does not support route domain.
    can you try this as a workaround?
    net route custom {
        gw %2
        network 10.11.248.0%0/24
