AndrewZew's avatar
AndrewZew
Mar 26, 2025
Terraform volterra problem
Hi Community,
I need some help:
I have a local generated certificate.pfx file and a password.
Where is the problem?
locals {
  certificate_content = filebase64(var.certificate_file)
  password_content = base64encode(var.certificate_password)
  password_string_format = "string:///${local.password_content}"
  string_format = "string:///${local.certificate_content}"
resource "volterra_certificate" "certificate-test" {
  name        = "certificate-test-03-26-25"
  namespace   = "tf-dev"
  description = "Simple Description"
  disable     = true
  private_key {
    clear_secret_info {
      url = local.password_string_format
  certificate_url       = local.string_format
  use_system_defaults   = true
  disable_ocsp_stapling = true
volterra_certificate.certificate-test: Creating...
│ Error: error creating Certificate: Creating object: Post "/public/namespaces/tf-dev/certificates": unsupported protocol scheme ""
│   with volterra_certificate.certificate-test,
│   on certificate.tf line 10, in resource "volterra_certificate" "certificate-test":
│   10: resource "volterra_certificate" "certificate-test" {
  • From what I see without testing it was probably the  "certificate-test-03-26-25" or the encoding as maybe the cert was already base64. It is good to share with the community what the issue was.
  • I received help from some community colleagues via private message. Thank you!
