Troy's avatar
Troy
Aug 27, 2024
Sync-issue when configured FQDN Node to pool with autopopulate enabled
In relation to this article https://my.f5.com/manage/s/article/K02805156, we resolved the issue by manually configuring the FQDN nodes to pool on the paired device prior to syncing.
  • Sadly we don't use FQDN because it comes with some limitations such as not being able to disable individual pool members that are auto-populated from DNS records. Ideally we should be using a higher layer health monitor but in some instances those can't be used and it makes it significantly more difficult to pull servers out of rotation without disabling a large group. Good find and thank you for publishing.
