jforaker's avatar
jforaker
May 16, 2008
Super HTTP monitor not working with NTLM
Hello everyone. I am attempting to use the external monitor script that Kirk Bauer provided on the wiki for Super HTTP monitor (http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/SuperHTTPMonitor.html).
We have a need to monitor our sites using NTLM authentication. We use a domain account for authorization and want to check for the 200 OK status after the NTLM authentication. I have created the script in the /usr/bin/monitors and I have the proper permission. The monitor is getting called from the LTM external monitor. We are running 9.3.1 HF1
[root@F501:Active] monitors pwd
/usr/bin/monitors
[root@F501:Active] monitors ls -l Super_HTTP_monitor
-rwx------ 1 root webusers 14686 May 13 20:11 Super_HTTP_monitor
[root@F501:Active] monitors b monitor SharePoint_external list
monitor SharePoint_external {
defaults from external
interval 15
timeout 46
AUTHTYPE "ntlm"
DEBUG "1"
LOG_FAILURES "1"
PASSWORD ""
run "Super_HTTP_monitor"
URI_PATH "/Pages/Default.aspx"
USERNAME ""
The script appears to be connecting to the webserver and completing the NTLM authentication. However the status check for 200 is failing since the first HTTP response seen on the output is 401. I’m not too good in writing scripts but I can troubleshoot them a bit. I see that the status code gets checked in the script with the following code:
Validate Check Conditions
[ -n "$status_code" ] || [ -n "$not_status_code" ] && {
local actual_status_code=$(head -n 1 "$tmpfile" | sed "s/^HTTP\/.\.. \([0123456789][0123456789][0123456789]\) .*$/\1/")
The first line of the temp file is the 401 response. The 200 OK response is the next server response. Here are the first 25 lines of the tmpfile the script checks.
root@F501:Active] monitors head -n 25 /var/run/.10.35.120.219.80.tmp
HTTP/1.1 401 Unauthorized
Content-Length: 1539
Content-Type: text/html
Server: Microsoft-IIS/6.0
WWW-Authenticate: NTLM TlRMTVNTUAACAAAAAAAAADgAAAACAgACdpOsRUS8WK8AAAAAAAAAAAAAAAA4AAAABQLODgAAAA8=
X-Powered-By: ASP.NET
MicrosoftSharePointTeamServices: 12.0.0.6219
Date: Fri, 16 May 2008 20:43:08 GMT
HTTP/1.1 200 OK
X-AspNet-Version: 2.0.50727
Set-Cookie: WSS_KeepSessionAuthenticated=80; path=/
Cache-Control: private, max-age=0
Expires: Thu, 01 May 2008 20:43:08 GMT
Last-Modified: Fri, 16 May 2008 20:43:08 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 37210
So my first question is how do I get the monitor to check the right server response? Is the server reponse the correct one for an NTLM authenticated session?
Thanks,
Jeff Foraker
  • Patrick_Chang_7's avatar
    Patrick_Chang_7
    Historic F5 Account
    head -n 1 tells the script to check only the HTTP status code in the first line of the response. This part of the script needs to be changed to check the second status code you get back.
