STREAM::match with case insensitivity
TMOS 11.3.0 HF6
Is it possible to STREAM::match or STREAM::expression with case insensitivity?
Example values which need to be evaluated as the same value: Host_ONE / HOST_ONE / host_one
Thanks.
- Kevin_Stewart
Employee
Not easily, unfortunately. You can try this though:
STREAM::expression {@[Hh][Oo][Ss][Tt]_[Oo][Nn][Ee]@host_one@} 🙂
Do you know if you could you use (?i) like this, does it need escaping:
STREAM::expression {@(?i)host_one@host_two@}- Kevin_Stewart
Employee
I don't believe this will work.
