Andy_Herrman_22
Nov 01, 2007SSL Tunneling and HTTP Connect
I'm looking at setting up HTTPS tunneling for our application's protocol so we don't have problems with firewalls/proxies blocking our connections. I still haven't been able to figure out quite how HTTPS tunneling works, but it looks like after I send a CONNECT message any proxies in place would start tunneling, allowing asynchronous communication (instead of the normal HTTP synchronous communication).
Assuming that's correct...
Would it be possible to have the F5 do SSL termination for this? Would it handle the asynchronous data, or would it be expecting synchronous HTTP requests?
- Deb_Allen_18Historic F5 AccountActually, you'll need to disable HTTP processing for CONNECT events, so it's sort of a moot point, HTTP-wise: It would simply be a TCP connection at that point.
Here's an article with some helpful details on how to configure a virtual server for tunneling:
Click here
HTH
/deb - Deb_Allen_18Historic F5 Account(whoops, sorry, wrong URL -- try it now)
