patonbike_25784's avatar
patonbike_25784
Aug 09, 2018
SQL Monitor question / problem...
Is it possible to run a SQL query and depending on the result put a pool member up or down? The problem here is that the SQL query is not running against the pool member.
  • Yes. Both the MSSQL and MySQL monitors have fields where you can put an alias address (the address of the SQL server you want to check) and depending on whether the check is successful or not your pool member(s) will be marked UP/DOWN.
    • patonbike's avatar
      patonbike
      Icon for Cirrus rankCirrus
      It looks like the fields are only editable when you create a new monitor for the first time . Once it has been created they cannot be modified.. That is what the problem was.
    • Ryannnnnnnnn's avatar
      Ryannnnnnnnn
      The fields should be editable if you create a new monitor and do as Ngutierrez31 said (select the relevant SQL monitor as the parent).
      patonbike
      IT won't let me fill out the alias fields. They are not editable.
      patonbike
    • Ryan_80361's avatar
      Ryan_80361
      patonbike
