A__N_5261
Dec 13, 2012SNAT for Specific Subnet
Hi ,
we have 5 VIP we have enable Snat on pool member. can we enable SNAT in this way if traffic coming from 10.0.0.0/8 subnet. Snat should work otherwise not. is there any way with Irule or another way to do that.
A.N
- Ajmal_2608
This should help
when CLIENT_ACCEPTED {
if { [IP::addr [IP::remote_addr] equals 10.0.0.0/8] } {
snat automap
return
} - What_Lies_Bene1
An SNAT is specified at the Virtual Server level, not the Pool or Member level. An iRule would be your best bet, something like this;when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 10.0.0.0/8] } { Use SNAT Automap if client IP is in this range snat automap Alternatively, specify a SNAT Pool instead snatpool name Stop processing the iRule for this event return } else { Stop processing the iRule for this event if no match return } } - What_Lies_Bene1
Sorry Ajmaluddin, didn't spot your post till I'd saved mine. - A__N_5261
But we have only option to enable SNAT on pool level not on VIP level. let me correct if i am wrong
A.N - What_Lies_Bene1
You can only SNAT at the VIP level. However, if you specify a pool within an iRule you can SNAT differently per pool. Please clarify your requirements. - A__N_5261
yes. i am looking for VIP level.
Thanks for your help
just last question . can we add two subnet as source in same IRULE . Like 10.0.0.0/8 and 192.168.2.0/24
Thanks & Regards
Great. You could add a second like this, there a few other ways you could do it too;when CLIENT_ACCEPTED { if { (([IP::addr [IP::client_addr] equals 10.0.0.0/8]) or ([IP::addr [IP::client_addr] equals 192.168.2.0/24 ])) } { Use SNAT Automap if client IP is in this range snat automap Alternatively, specify a SNAT Pool instead snatpool name Stop processing the iRule for this event return } else { Stop processing the iRule for this event if no match return } } - What_Lies_Bene1
This is a longer method but allows for different actions based on the source subnet;when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 10.0.0.0/8] } { Use SNAT Automap if client IP is in this range snat automap Stop processing the iRule for this event return } elseif { [IP::addr [IP::client_addr] equals 192.168.2.0/24] } { snatpool name Stop processing the iRule for this event return } else { Stop processing the iRule for this event if no match return } }
