Piers_72246's avatar
Piers_72246
Oct 24, 2012
Snap-in installed but cmdlets not visible
So I have the snapin installed and have a script that starts off with this code, straight from examples here
if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null )
Add-PSSnapIn iControlSnapIn
$success = Initialize-F5.iControl -HostName $bigip -Username $user -Password $pass
I run it the first time and everything works fine. Subsequent times I get this error:
Get-Command : The term 'iControlSnapIn' is not recognized as the name of a cmdlet, function, script file, or operable program.
The first command works and the snap-in is detected:
PSVersion : 2.0
Description : iControl Snap-in for F5 Device Management
but it won't let me call the cmdlets. Any idea why?
  • That's odd. What line is the "Get-Command" error coming from? I don't see you using Get-Command in the code.
    After you successfully call Add-PSSnapin, what is the output of the following
    PS> Get-F5.Commands
    or
    PS> Get-Command *-F5.*
    or
    PS> Get-Command Initialize-F5.iControl
    -Joe
  • Sorry,
    The Get-Command error happens at this line
    additionally after I run it once (and hit the Add-PSSnapIn the first time if I run the commands you suggested I get the same error e.g.
    Get-Command : The term 'Initialize-F5.iControl' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the
     name, or if a path was included, verify that the path is correct and try again.
    At line:1 char:12
    + Get-Command <<<<  Initialize-F5.iControl
        + CategoryInfo          : ObjectNotFound: (Initialize-F5.iControl:String) [Get-Command], CommandNotFoundException
        + FullyQualifiedErrorId : CommandNotFoundException,Microsoft.PowerShell.Commands.GetCommandCommand
  • Ok, let's start from the beginning.
    First you need to run the setupSnapin.ps1 file in the "c:\program files (x86)\F5 Networks\iControlSnapin" installation directory. This will add the snapin to the registry. Maybe you missed this step...
    PS C:\Program files (x86)\F5 Networks\iControlSnapin> .\setupSnapin.ps1 -force
    Keep in mind that you will need run this as Administrator as it updatest the registry.
    Then this command should then return the following:
    PS> Get-PSSnapin -Registered iControlSnapin
    PSVersion   : 2.0
    Then you'll need to add the snapin to your current runspace
    PS> Add-PSSnapin iControlSnapin
    Then running the Get-PSSnapin should return the snapin info:
    PS> Get-PSSnapin iControlSnapin
    PSVersion   : 2.0
    At this point, the snapin is loaded in the runspace and you should be able to get the exported cmdlets from the snapin:
    PS> Get-Command -Module iControlSnapin
    CommandType     Name
    Cmdlet          Add-F5.LTMPoolMember
    Cmdlet          Add-F5.LTMVirtualServerRule
    And the Initialize-F5.iControl cmdlet should be there too
    PS> Get-Command -Module iControlSnapin Initialize-F5.iControl
    CommandType     Name
    Cmdlet          Initialize-F5.iControl
    Could you run through those steps and see where things break down.
    -Joe
  • Sorry, I wasn't clear.
    The installation and registration of the snap-in works. As does my script (it removes nodes from a pool during code deployment), however the script only works the first time. Here's what happens
    I open the myscript.ps1 in powershell ISE and run it. It h runs through the code block in my first post:
     if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null ) { Add-PSSnapIn iControlSnapIn } $success = Initialize-F5.iControl -HostName $bigip -Username $user -Password $pass
    and, doesn't find the snap in so it runs the Add-PSSnapIn command returns success and goes on to execute the remainder of the script.
    If I then run this command, I see that the snap-in is present in my current runtime
     PS C:\Windows\system32> Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"} Name : iControlSnapIn PSVersion : 2.0 Description : iControl Snap-in for F5 Device Management
    However calling an F5 specific cmdlet after that doesn't work after that. Example:
     PS C:\Windows\system32> Get-Command -Module iControlSnapin Initialize-F5.iControl Get-Command : The term 'Initialize-F5.iControl' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again. At line:1 char:12 + Get-Command <<<< -Module iControlSnapin Initialize-F5.iControl + CategoryInfo : ObjectNotFound: (Initialize-F5.iControl:String) [Get-Command], CommandNotFoundException + FullyQualifiedErrorId : CommandNotFoundException,Microsoft.PowerShell.Commands.GetCommandCommand
    Subsequent runs of my script also fail after this because of it's dependacy on F5 cmdlets
    edit: forum styling grrrrrrrr
  • What does "Get-Command -Module iControlSnapin" return after you've successfully added the Snapin? If it's an empty list them something is wrong with the Snapin Install. I've been using the snapins for years now and haven't had this issue with the command prompt or ISE.
  • Yep, it's empty.
    _________________________________________________________________________________________________________________________
    I'll try re-installing.
