Barbara_Cob_149's avatar
Barbara_Cob_149
Apr 04, 2014
smb monitor example
smb monitor example
  • An example can be found here:
    https://devcentral.f5.com/questions/smb-monitor-2008-file-share
    Be aware though that SMB monitors are broken starting in v10.1.0 through v11.3. Here is an alternative option if you are not running at least v11.4:
    https://devcentral.f5.com/wiki/AdvDesignConfig.Windows-File-Share-Monitor-SMB-CIFS.ashx
  • Hi Cory, If the netbios is disabled in the smb.comf file, is there any way to make the smb monitor work? Right now I get the following errors: Invalid packet length, recieving SMB: Server stopped responding, session request to LTS1A failed, session request to *SMBSERVER failed.
    The smbclient call is as follows: smbclient -N -L LTS1A -I 10.90.43.111 -p 22
    smb.conf contains: disable netbios = yes netbios name = LTS1A workgroup = LTS1 server string = LTS1
    Thanks, Barbara
