ArunKumarV_3226's avatar
ArunKumarV_3226
May 31, 2017
Setting UP Connection Timeout to Application 1000 sec
I have an application A how to change the Connection Timeout for the application A in F5 BIGIP Load Balancer.
How to set the connection timeout to 1000sec's.
Please provide the steps to setup the connection timeout.Thanks!
  • Hi,
    I think you want to set up the idle timeout of the connection in order not to disrupt traffic.
    You could modify the TCP profile associated to the Virtual Server or you can create a new one in:
    Local Traffic ›› Profiles : Protocol : TCP ›› TCP Profile...
    and set the Idle Timeout option with a value of 1000.
    I hope this helps.
    Pedro
