Session issue with two different LTM/APM devices
We are experiencing issue with APM Session. The problem is that when users access to second site on a different LTM, then their session for first connected site get killed.
We are using two different Access Profile (LTM1 and LTM2), but using the same Domain example.com
Scenario: 1. User connected/logon to extranet.domain.com (LTM 1) site 2. Next user open another browser tab or window connected/logon to te.example.com (LTM2) 3. Once user go back to extranet.example.com (LTM1), session was killed. User will have to logon again or get an error about invalid session ID.
We would like to find a way to allow users to switch back-n-forth between sites (LTM 1 and LTM 2) without forcing them to logon again or to avoid getting Invalid session error. Is that possible?
- Seth_Cooper
Employee
The issue is because you have the same cookie domain and the MRHSession Cookie (the cookie that APM uses to track your session) is overwritten by the 2nd APM you login into. When you go back to the first APM the cookie is from the 2nd and it doesn't know who you are since it is a value from the other APM.
You can specify a more specific cookie domain in the Access Profile.
Seth
- jdewing
Cirrus
I tried changing Cookie Domain name to te.example.com or example-test.com under Access Profile and getting an error "Your session could not be established". The Domain name must be example.com to work with Kerberos.
I thought about creating iRule. Does anyone have an example of iRule to create a separate cookie so it doesn’t get overwritten by the first APM cookie?
- stan_piron
Cumulonimbus
blank the cookie domain. the cookie sent in the answer will not contain domain information and the browser will record it as a cookie dedicated for the requested hostname.
- jdewing
Cirrus
We can't blank the cookie domain because we have multiple VIPs using same LTM1 to provide SSO. We don’t want user to able to logon each time they go to different site under LTM1.
- stan_piron
Cumulonimbus
The best way to authenticate once and keep authenticated on both APM is to configure SAML.
You can create a VS with SAML IdP Role and each other VS are defined as SAML Service Provider.
another solution is to configure multi domain cookie... but you will need to authenticate once on each APM.
