George_33482's avatar
George_33482
Mar 07, 2012
Server-initiated Connection what to do?
Hello,
i have a deployment of an ASM in few days and i need to clarify some points(if possible).
The ASM should be installed in a DMZ of a firewall and the server default gateway is the ASM.
the connection will be Client->Outside of Firewall->DMZ of firewall (ASM)-> web server.
off course all the necessary configuration will be done such as creating a virtual server and
bind it to a class.....etc.
The question is what to do on ASM if the server will initiate the connection??? The connection will be to a database server or any server which resides inside the LAN (Firewall inside).
Do i have to create a VS and assign it to the vlan facing the server, then bind a snat to it?
Is there any other ways?
Regards,
George
  • hoolio's avatar
    hoolio
    Hi George,
    A VS would be ideal. If you want to set idle timeouts and/or optimized profiles per protocol, you could create port specific virtual servers.
    Aaron
  • Hi Aaron,
    Thank you for your support.
    Why I would set or change timeouts or use profiles?
    Regards,
  • hoolio's avatar
    hoolio
    For example, you could create a 0.0.0.0:80 VS with a TCP idle timeout set low (maybe 100 seconds) and a 0.0.0.0:3389 VS with a longer idle timeout for RDP (maybe 8 hours?).
    sol7166: Changing the idle timeout for a protocol profile
    http://support.f5.com/kb/en-us/solutions/public/7000/100/sol7166.html
    Aaron
