blahblahdab1ah_'s avatar
blahblahdab1ah_
Jul 07, 2016
Solved
Selective SNAT problem
I have a node in a pool trying to reach a virtual server that references the same pool. Using the code below does work with one caveat: the node in the pool can only reach itself.
If the service on the node is disabled, the connection wont get made.
Basically I need it to load balance between the other nodes in the pool in case the service on the node gets compromised. Here is where I pulled the general code.
Specifically, this portion:
" And another option for using SNAT only if the client IP is a node in the pool:
when CLIENT_ACCEPTED { Check if the client IP address is a node in the VIP's default pool if {[matchclass [IP::client_addr] equals [active_nodes -list [LB::server pool]]]}{
  log local0. "SNAT'ing for [IP::client_addr], member of pool [LB::server pool]"
  snat automap
Thanks!
  • This is the version that worked in this scenario:
    when LB_SELECTED {
    if {[IP::addr "[IP::client_addr]/24" equals "[LB::server addr]/24"]} {
    snat automap } }
    Thanks for the help!
  • Let's take a packet capture.
    tcpdump -ni 0.0:nnnp -s0 -w /var/tmp/snat.pcap host -vvv
    when LB_SELECTED {
    snat automap } }
