Security policy supports Multi-languague web application " arabic,English....
we had some of applications that support many languages as Arabic , English , in creating a security policy , i should define application language or leave it to auto-detect , in both cases i only define one language ..........................
should i create a separate security policy for every language ???
or
can i create a security policy that match multiple languages ???
- PeteWhite
Employee
Essentially you need to use a different security policy per application language. Obviously this is important for parameters, values etc but if you have a very simple policy then you may get away with using just utf-8.
Otherwise, create different security policies and use the ltm policy to map different URLs or whatever to different ASM security policies.
- Ahmed_Eissa_206
ummm ... thanks ...it is a good tip " utf-8"
