alkjones_3684
Jul 15, 2012'secure' and httponly' attribute for aspsessionid* cookies
ive searched for various terms here and found nothing so apologies if im doubling up a question thats already been answered numerous times.
I need to set secure and httponly attributes on aspsessionid* cookies.
this:
when HTTP_RESPONSE {
foreach cookie [HTTP::cookie names] {
HTTP::cookie secure $cookie enable
works fine at setting the secure attribute
this however:
HTTP::cookie httponly $cookie enable
completely denies access to the site - I dont even get to the logon page of my application.
I VERY MUCH need to set both value on my cookies or my pen test tomorrow is not going to go well for me..
this rule - written as part of F5 consultauing services - DOES set both attributes, but does a load of other suff that prevents access to one of my application that is very about what is passed through in the header:
HTTP::header replace "User-Agent" "[HTTP::header User-Agent] IPSOURCE: [IP::client_addr]"
set value [HTTP::cookie value $cookie]
set path [HTTP::cookie path $cookie]
set domain [HTTP::cookie domain $cookie]
HTTP::cookie remove $cookie
HTTP::cookie insert name $cookie value $value version 1
if { $path ne "" } { HTTP::cookie path $cookie $path }
if { $domain ne "" } { HTTP::cookie domain $cookie $domain }
any help would be gratefully appreciated - yes I HAVE rebooted my kit so as not to be caught out by the 49 day bug ( or whatever the time frame is..)
goign round in circles and frankly starting to lose my mind..
Cheers
Alastair
(F5 3900 X2 LTM 11.1 HF1)
- alkjones_3684
the solution provided by a rather awesome support engineer:
when HTTP_RESPONSE { set myValues [HTTP::cookie names] foreach mycookies $myValues { if { [HTTP::cookie expires $mycookies] eq "" }{ set mypath [HTTP::cookie path $mycookies] set myvalue [HTTP::cookie $mycookies] HTTP::cookie remove $mycookies HTTP::cookie insert name $mycookies value $myvalue version 1 HTTP::cookie httponly $mycookies enable HTTP::cookie secure $mycookies enable if { $mypath ne "" } { HTTP::cookie path $mycookies $mypath } } else { HTTP::cookie secure $mycookies enable } } }
its late, so you can do the formatting yourself..
NOTE -
Duplicate cookies will definitely give you problems when using this irule.
NON-RFC compliant cookies will probably give you a problem when using this irule..
Cheers
Alastair
