Saml SSO 4 SP with same IDP
My Big IP As SP
I have 4 VS configured with APM saml SSO
Every VS configured with Saml SP Services
all the SP services bind to same IDP connector
when USER accept in APM they can move to another VIP and when a client in another VS click to start SSO
they automatically authorized because Because he made an identification with saml
I can solve this issue with some way
- youssef1
Cumulonimbus
Hi Igor.
Can you explain what is your issue. And what's you need exactly?
Regards
- igorzhuk
Altostratus
Hi Youssef I have 4 VS on my F5 All VS configured with SSO saml authentication with same IDP when I connect to VS after authentication I permit to MYAPP
after I go to my other VS in the same session I try to Join MYAPP2 I don't need authentication with IDP because I don't do logout from MYAPP
- youssef1
Cumulonimbus
Hi Igor.
In fact it's a normal behaviour. You have 4 Service provider bind to the same IDP (authentication federation).
According to the timeout that you set on your IDP, all SP don't need authentication while IDP session is still alive.
So the behaviour that you indicate is normal and wanted in this kind of architecture.
But If I understand, you want that user have to re-authenticate for each application? In this case why thou federated authentication?
Regards
