SAML IDP using CAC auth
I've setup as an IDP and have a VS with an access policy that prompts for the user's CAC. I want to take the EDPI number(10-digit) of the CAC and pass it on the SP as an attribute in the assertion. The default assertion subject value does not have an option...only the 6 below: Is there a way?
%{session.ad.last.attr.name} %{session.ad.last.attr.sAMAccountName} %{session.ad.last.attr.userPrincipalName} %{session.logon.last.logonname} %{session.logon.last.username} %{session.sso.token.last.username}
- RobertWebb_7911
I have had to grab the EDPI before but it has been a while so I am a little foggy on exactly how I did.
But from what I recall, I created a custom variable then parsed put the EDIPI from the CN.
If you have trouble figuring out hot to do it, I will try and look back though my notes. It has been about a year since I had to do it, and I am no longer doing F5 work.
- Sonny
Cirrus
Yes, if you could go though your notes that would be appreciated.
- MichaelatF5
Employee
Sonny, please feel free to reach out to your account team offline. We do not like to post Federal configuration documents on DC, but they are readily available.
If you aren't sure who to reach out to, You can message me direct and I can get you in touch with the right team.
- Sonny
Cirrus
Okay Mike. I'll reach out to them.
