Client Auth Using HTTP Cookie
Problem this snippet solves:
This is an example using HTTP cookie for authentication. If authentication is successful, a cookie will be sent to client. If next time, the AUTH cookie is present and valid, client will be passed immediately without being checked with AAA server. The cookie name, password, domain should be properly modified by user. This rule is for radius AUTH. If replacing radius with ldap or tacacs, it works too.
Code :
when CLIENT_ACCEPTED {
set authinsck 0
set forceauth 1
set ckname BIGXAUTH
set ckpass 1xxx5678
set ckvalue [IP::client_addr]
set ckdomain .y.z
set asid [AUTH::start pam default_radius]
if {[HTTP::cookie exists $ckname]} {
HTTP::cookie decrypt $ckname $ckpass 128
if {[HTTP::cookie value $ckname] eq $ckvalue} {
set forceauth 0
HTTP::cookie remove $ckname
if {$forceauth eq 1} {
AUTH::username_credential $asid [HTTP::username]
AUTH::password_credential $asid [HTTP::password]
AUTH::authenticate $asid
HTTP::collect
when HTTP_RESPONSE {
if {$authinsck eq 1} {
HTTP::cookie insert name $ckname value $ckvalue path / domain $ckdomain
HTTP::cookie secure $ckname enable
HTTP::cookie encrypt $ckname $ckpass 128
when AUTH_SUCCESS {
if {$asid eq [AUTH::last_event_session_id]} {
set authinsck 1
HTTP::release
when AUTH_FAILURE {
HTTP::respond 401 "WWW-Authenticate" "Basic realm=\"\""
when AUTH_WANTCREDENTIAL {
when AUTH_ERROR {
HTTP::respond 401
}4 Comments
- swo0sh_gt_13163
Altostratus
Can I make it working with Local Database? I mean configuring Data group with Username and Password hash? If yes, any examples? Thank you! - Tosin_Omojola
Altostratus
I have an application which has a link to BIGIP on its webtop. When the BIGIP app link is clicked on the webtop, I want BIGIP to verify user session coming from there before passing it on to the servers its loadbalancing.
If the user is not authenticated, he should be redirected to the login page otherwise, grant access to the resource.
Please How can I achieve that with this code snippet or other? Thanks
- Tosin_Omojola
Altostratus
I guess this page is not monitored for user comments and questions...
- Habib_Ulla_Khan
I have a VIP (no apm). this is application used in ipad. Once user logins to ipad he gets buttons to navigate to different application (which are vip with APM). As user is already logged into main application. Anytime he clicks on buttons (links to different application), he should get cookie authentication. Where will i apply this irule.. Should i apply on main VIP or applications which are referred as buttons.
