eduardo_26187's avatar
eduardo_26187
Jan 28, 2010
Rule to hide port in client side
Hi, this is my first post.
I' ve googled about how to do this rule, but I have no idea so far:
After doing a redirect this way:
HTTP::redirect "https://[HTTP::host]:9081/Login.jsp"
I want to hide port 9081 to the user, but internally still managing port 9081 with websphere.
Thanks in advance.
  • Thanks Mr. hoollio,
    I already checked the section Rewrite HTTP Redirect Port, but is not what I am looking for, because I'd like to use the same port 9081 and hiding the TCP::local_port without showing any port in url.
    Checking the section STREAM::expression in the next example
    when HTTP_RESPONSE {
    Disable the stream filter by default
    STREAM::disable
    Check if response type is text
    if {[HTTP::header value Content-Type] contains "text"}{
    Match any http:// instance and replace it with nothing
    STREAM::expression {&http://.*?example\.com&&}
    Enable the stream filter for this response only
    STREAM::enable
    when STREAM_MATCHED {
    log local0. "[IP::client_addr]:[TCP::local_port]: matched: [STREAM::match], replaced with: [string map {http:// https://} [STREAM::match]]"
    STREAM::replace "[string map {http:// https://} [STREAM::match]]"
    I think this example replaces the string for logging which is not useful at all.
    What I'm still looking for is a rule like this (with the correct sintax):
    when http:response {
    if {
    http: [gethost][port 9081]
    hide_in_url port 9081
    http::redirect host:9081
    Thanks in advance
