VFB's avatar
VFB
Icon for Cirrus rankCirrus
11 years ago
rightfax scaling issue
I'm currently attemping to loabalance rightfax and for some reason, going through the F5, the transaction never scales and as a result, is very slow. going directly to the server, I noticed it was very fast, but the source kept sending a very small window size, as opposed to sending a large one via the F5.
going through F5:
flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0xf11f (correct), 70196:70196(0) ack 51049 win 64660 20:20:58.839247 IP (tos 0x0, ttl 255, id 17389, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 70196:71556(1360) ack 51049 win 64660 20:20:58.840105 IP (tos 0x0, ttl 255, id 17391, offset 0, flags [DF], proto: TCP (6), length: 744) 10.10.10.234.64731 > 192.168.11.11.10520: P 71556:72260(704) ack 51049 win 64660 20:20:58.840408 IP (tos 0x0, ttl 255, id 17399, offset 0, flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0xddba (correct), 72260:72260(0) ack 53075 win 65535 20:20:58.968870 IP (tos 0x0, ttl 255, id 17486, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 72260:73620(1360) ack 53075 win 65535 20:20:58.968875 IP (tos 0x0, ttl 255, id 17488, offset 0, flags [DF], proto: TCP (6), length: 744) 10.10.10.234.64731 > 192.168.11.11.10520: P 73620:74324(704) ack 53075 win 65535 20:20:58.969442 IP (tos 0x0, ttl 255, id 17493, offset 0, flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0xcdc0 (correct), 74324:74324(0) ack 55101 win 65535 20:20:59.097646 IP (tos 0x0, ttl 255, id 17603, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 74324:75684(1360) ack 55101 win 65535 20:20:59.098578 IP (tos 0x0, ttl 255, id 17605, offset 0, flags [DF], proto: TCP (6), length: 744) 10.10.10.234.64731 > 192.168.11.11.10520: P 75684:76388(704) ack 55101 win 65535 20:20:59.098880 IP (tos 0x0, ttl 255, id 17610, offset 0, flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0xbdc6 (correct), 76388:76388(0) ack 57127 win 65535 20:20:59.228072 IP (tos 0x0, ttl 255, id 17791, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 76388:77748(1360) ack 57127 win 65535 20:20:59.228076 IP (tos 0x0, ttl 255, id 17793, offset 0, flags [DF], proto: TCP (6), length: 744) 10.10.10.234.64731 > 192.168.11.11.10520: P 77748:78452(704) ack 57127 win 65535 20:20:59.228662 IP (tos 0x0, ttl 255, id 17798, offset 0, flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0xadcc (correct), 78452:78452(0) ack 59153 win 65535 20:20:59.354195 IP (tos 0x0, ttl 255, id 17906, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 78452:79812(1360) ack 59153 win 65535 20:20:59.354200 IP (tos 0x0, ttl 255, id 17908, offset 0, flags [DF], proto: TCP (6), length: 744) 10.10.10.234.64731 > 192.168.11.11.10520: P 79812:80516(704) ack 59153 win 65535 20:20:59.354780 IP (tos 0x0, ttl 255, id 17915, offset 0, flags [DF], proto: TCP (6), length: 40) 10.10.10.234.64731 > 192.168.11.11.10520: ., cksum 0x9dd2 (correct), 80516:80516(0) ack 61179 win 65535 20:20:59.480357 IP (tos 0x0, ttl 255, id 17988, offset 0, flags [DF], proto: TCP (6), length: 1400) 10.10.10.234.64731 > 192.168.11.11.10520: P 80516:81876(1360) ack 61179 win 65535
  • I was able to narrow the issue down to the upstream checkpoint fragmenting the bits. After enabling "do not fragment", things started working as expected.
