Brent_Grooms_89
Dec 03, 2007require ssl for IIS
I'm kind of new to iRules and wanted some help. In IIS web server there is an option to require ssl that you can enable for any directory. However, since we terminate ssl on the Big-IP, we cannot use this option. We have a new web application going in that will have a couple of directories that will require ssl. The rest of the site we want just http. Realizing that I will need two virtuals (one for standard http and one for https), how can I use iRules to make sure that those two portions of the site are always https and the rest is http?
Thanks,
Brent
- hoolio
If you have the ability to modify the web application you could configure the BIG-IP to insert a custom header for only the requests it receives via the HTTPS virtual server. The web application could look for this header and send a redirect to https back if the client requested a URI that you want requested only via HTTPS.
Else, you could add all of the logic to the BIG-IP. If you have a list of directories which you want to require SSL for, you could add them to a datagroup. You could then check each request to the HTTP virtual server against that list and redirect matching requests to the same host and URI, via HTTPS.
Here is an example using a datagroup (AKA class):
(datagroups are separate objects from iRules. You can create a datagroup under Local Traffic >> iRules >> Datagroups tab)Datagroup listing HTTPS-only resources class secure_pages_class { "/https/" "/other_secure_dir/" "/one/secure/page.txt" }triggered when BIG-IP parses the HTTP headers of a request when HTTP_REQUEST { Check if any entry in the class starts with the path of the request, set to lower case if {[matchclass [string tolower [HTTP::path]] starts_with $::secure_pages_class]}{ Comment out this log statement when done testing this rule log local0. "Redirecting client [IP::client_addr] who requested [HTTP::uri], with path \ of [HTTP::path] to TCP port [TCP::local_port] to https://[HTTP::host][HTTP::uri]" If so, redirect the request via https to the same host and URI HTTP::redirect https://[HTTP::host][HTTP::uri] } }
Aaron
