Rename header in response and keep value
Hi hopefully this is really easy i just didnt see anything. I just need to take a request header that comes in and rename it in a response header keeping the same value.
Header named email has a value of [email protected] needs to be sent in the response to the sender as email allowed with the value [email protected]
you just need an iRule in the following sequence :1- save the Header value that comes in HTTP Request in a variable :
set Req_header [HTTP::header value "email"]2- Then insert Header value again under HTTP_Response event again.
Please have a look in this article : https://community.f5.com/discussions/technicalforum/irule-to-add-the-server-header-in-the-http-response-please-help/113097
look at Kai_Wilke reply >> it will give u an insight of how doing this.
Let me know if it doesn't worked with you.
