OM's avatar
OM
Dec 17, 2015
Remote Role Group for Resource Administrator
hi,
I'm trying to restrict access to the common partition for Resource Administrator assigned role. I this something feasible? Does the Common partition give access to everything by default?
thanks.
  • That particular role grants complete access to all partitioned and non-partitioned objects on the system except for user accounts. The manager role will allow you to create objects in the partition in which the user is assigned, and view but not change objects in the Common partition. For more details on roles and lines of delineation with them, consult the manual.
