remapping issue
I need some help with irule (or any other solution that will help) I have to make my URLs shorter so I’m doing below remapping
`Code`
HTTP::uri [string map -nocase {"/" "/xxxxx"} [HTTP::uri]]
}Original link looks like that: https://link.domain.com/xxxxx and after remapping https://link.domain.com/
It causing one problem – logo image located on this site disappear after remapping So this is effect of this remapping https://link.domain.com/images/logo.png but it should look like that https://link.domain.com/xxxxx/images/logo.png
how can I prevent it? of course i want to make my link shorter but i want to exclude such behavior.
- VernonWells
Employee
The
substitutes every instance of / for /xxxxx. Thus, if the path-uri were /, it would change the path-uri to /xxxxx. If the path-uri were /foo/bar, it would change the path-uri to /xxxxxfoo/xxxxxbar. I believe what you are attempting to do is insert a path element at the start of any submitted path-uri, so that:string map- if the user-agent requests http://link.domain.com/, the server sees /xxxxx/ as the request path-uri;
- if the user-agent requests http://link.domain.com/foo/bar, the server sees /xxxxx/foo/bar as the request path-uri;
- if the user-agent requests http://link.domain.com/images/logo.png, the server sees /xxxxx/images/logo.png as the request path-uri.
Is that correct? If so, then you should be able to simply do this:
when HTTP_REQUEST { HTTP::uri "/xxxxx[HTTP::uri]" }If you are using BIG-IP 11.4 or higher, you could also use a Local Traffic Policy:
ltm policy expand-path { controls { forwarding } requires { http } rules { rule01 { actions { 0 { http-uri replace path /xxxxx[HTTP::uri] } } ordinal 2 } } strategy first-match } - numen_235631
thanks for you support!
