Kalana
Feb 26, 2016redirecting http host to same https modified uri
I would like to achieve following scenario,
http://abc.xyz.com ------> Redirect to https://abc.xyz.com/abc
http to https ltm built in conversion has been assigned and functioning, few attempts resulted in creating a redirection loop.
Cheers,
Kalana
Hi Kalana,
you could copy and then customize the build-in "_sys_https_redirect" iRule as needed. To change redirect to a specific and fixed URI you could use the iRule below as a starting point...
when HTTP_REQUEST { HTTP::redirect "https://[getfield [HTTP::host] ":" 1]/insert_your_uri" }Note: You have to assign the iRule to the HTTP virtual server only.
Cheers, Kai
